Mk2 Cooper S Demister vent tubes https://ausmini.com/forums/viewtopic.php?f=2&t=95384 |
Page 1 of 3 |
Author: | mini210 [ Fri May 12, 2017 11:22 pm ] |
Post subject: | Mk2 Cooper S Demister vent tubes |
Are the demister vent tubes to suit a Mk2 Cooper S plastic heater available as a reproduction anywhere? If so how exact are they to the original? Or if not available would anybody know where to source some good second hand ones from or are they rare as hens teeth... ![]() Mark |
Author: | Raz [ Sun May 14, 2017 1:02 pm ] |
Post subject: | Re: Mk2 Cooper S Demister vent tubes |
http://oz.minisport.com/czh1753-heater- ... -1992.html I'm in need of the same on mine, this was the only local pipe I had seen. |
Author: | mini210 [ Sun May 14, 2017 1:08 pm ] |
Raz wrote: http://oz.minisport.com/czh1753-heater-ducting-pipe-to-screen-22-5-x-1-25-1967-1992.html I'm in need of the same on mine, this was the only local pipe I had seen. Thanks Raz! Not sure how close to the originals they are but il get in contact with them to see. Thanks again mate! ![]() |
Author: | gtogreen1969 [ Sun May 14, 2017 1:46 pm ] |
I may have some in a box somewhere in the shed. I saw 3 of them a few years ago. Are they a convoluted plastic about 40mm diameter? |
Author: | winabbey [ Sun May 14, 2017 2:36 pm ] |
MKO has genuine Rover versions. http://minikingdomonline.com.au/product ... over-part/ |
Author: | Raz [ Sun May 14, 2017 3:03 pm ] |
gtogreen1969 wrote: I may have some in a box somewhere in the shed. I saw 3 of them a few years ago. Are they a convoluted plastic about 40mm diameter? I believe the original mk1 are fibre/foil and mk2 onwards was plastic, not sure but assume the rover fit just the same. |
Author: | Bubbacluby [ Sun May 14, 2017 6:14 pm ] |
Strange how the mk2 got plastic and the clubman GT went back to the cardboard and aluminium tubing. Mk2 2 is very similar to household vacuume pipe isn't it? Sent from my SM-G935F using Tapatalk |
Author: | simon k [ Sun May 14, 2017 7:20 pm ] |
Bubbacluby wrote: Strange how the mk2 got plastic and the clubman GT went back to the cardboard and aluminium tubing. Mk2 2 is very similar to household vacuume pipe isn't it? Sent from my SM-G935F using Tapatalk not on my 7/70 car... I'm 99.99% sure mine is original and it's paper/foil |
Author: | winabbey [ Sun May 14, 2017 7:26 pm ] |
simon k wrote: Bubbacluby wrote: Strange how the mk2 got plastic and the clubman GT went back to the cardboard and aluminium tubing. Mk2 2 is very similar to household vacuume pipe isn't it? Sent from my SM-G935F using Tapatalk not on my 7/70 car... I'm 99.99% sure mine is original and it's paper/foil Yes, black paper and inner foil on my Sept 70 MK II. |
Author: | Bubbacluby [ Sun May 14, 2017 7:59 pm ] |
Ok. Makes sense now. Thanks. Now to find kopex in the correct diameter. The tubing is still available if you search hard enough. Sent from my SM-G935F using Tapatalk |
Author: | mini210 [ Sun May 14, 2017 8:03 pm ] |
Thanks guys for your knowledgeable input. Really appreciated! The year of my MK2 is the same as Simons- 7/70 so it would appear to be the black paper/inner foil type? Thanks Brad, if you have this type or anyone, id be interested in them if there in good nick but hearing there construction it may be hard to find an intact good set? Bubbacluby- Is Kopex the brand name or product name of this black paper/inner foil type tubing? |
Author: | gtogreen1969 [ Sun May 14, 2017 11:24 pm ] |
mini210 wrote: Thanks guys for your knowledgeable input. Really appreciated! The year of my MK2 is the same as Simons- 7/70 so it would appear to be the black paper/inner foil type? Thanks Brad, if you have this type or anyone, id be interested in them if there in good nick but hearing there construction it may be hard to find an intact good set? Bubbacluby- Is Kopex the brand name or product name of this black paper/inner foil type tubing? Here are a few photos of the ones i have. They must be later leyland ones. I have never really taken any notice of the ducting before. Out of sight out of mind. ![]() ![]() |
Author: | simon k [ Mon May 15, 2017 4:37 pm ] |
sounds like early Porsches use the same stuff... http://www.early911sregistry.org/forums ... php?111174 |
Author: | simon k [ Mon May 15, 2017 4:39 pm ] |
wooo.... looks a lot like this: https://www.aasesales.com/products/g2e-s54-8i-103189 $10 a piece would be worth having a look - though 55mm might be too big, need to measure |
Author: | simon k [ Mon May 15, 2017 4:51 pm ] |
hahaha!! "aluminiumflexibledutcing.com" http://www.aluminumflexibleducting.com/ ... -hose.html |
Page 1 of 3 | All times are UTC + 10 hours |
