SU needles https://ausmini.com/forums/viewtopic.php?f=2&t=95375 |
Author: | AWOODY [ Wed May 10, 2017 8:40 pm ] |
Post subject: | SU needles |
Need some advice on needle selection for an engine with the following specs Twin hs2 su 1310 flowed head 266ss cam maniflow freeflow extractors rc40 3.2 diff currently have M needles |
Author: | drmini in aust [ Thu May 11, 2017 6:51 am ] |
Post subject: | Re: SU needles |
If running sports filters try AH2. |
Author: | AWOODY [ Thu May 11, 2017 5:19 pm ] |
Yes unifilter socks . |
Author: | carbon [ Sat May 13, 2017 5:32 am ] |
AH2 is good starting point for this spec with old red springs, which are not as strong as the red springs currently supplied. If you're using new red springs then M needles probably won't be far off. If you're using blue springs then try QA needles, almost identical to AH2 for first half opening then gets a tad richer. |
Author: | AWOODY [ Sun May 14, 2017 8:33 pm ] |
Thanks . |
