It is currently Sun Jul 20, 2025 11:57 am
 Post subject: SU needles
PostPosted: Wed May 10, 2017 8:40 pm
Need some advice on needle selection for an engine with the following specs
Twin hs2 su
1310
flowed head
266ss cam
maniflow freeflow extractors
rc40
3.2 diff
currently have M needles
 Post subject: Re: SU needles
PostPosted: Thu May 11, 2017 6:51 am
If running sports filters try AH2.
PostPosted: Thu May 11, 2017 5:19 pm
Yes unifilter socks .
PostPosted: Sat May 13, 2017 5:32 am
AH2 is good starting point for this spec with old red springs, which are not as strong as the red springs currently supplied. If you're using new red springs then M needles probably won't be far off.
If you're using blue springs then try QA needles, almost identical to AH2 for first half opening then gets a tad richer.
PostPosted: Sun May 14, 2017 8:33 pm
Thanks .
