Fuel Sender Question. https://ausmini.com/forums/viewtopic.php?f=2&t=95347 |
Author: | minijcar [ Mon May 08, 2017 7:06 pm ] |
Post subject: | Re: Fuel Sender Question. |
Parameters? |
Author: | flapper [ Mon May 08, 2017 8:17 pm ] |
minijcar wrote: Parameters? Can you please clarify you question? |
Author: | gtogreen1969 [ Mon May 08, 2017 8:41 pm ] |
Check the ohms reading from empty to full. 250-19 ohms if its post Sep 1964. 83-3 ohms prior to this. I think. Maybe. |
Author: | flapper [ Mon May 08, 2017 10:48 pm ] |
gtogreen1969 wrote: Check the ohms reading from empty to full. 250-19 ohms if its post Sep 1964. 83-3 ohms prior to this. I think. Maybe. Have checked the ohms reading as well as one can, we are going from 90-6 which means it is not suitable for our 850 gauge. It does have a number FTS2330/00 were our 850 one's have the number FT2330/05 (which means nothing to us) It still seems an odd sender, as it does not have push on terminals as I thought all Deluxe's had. It has a removable tin float also. Thank you |
Author: | gtogreen1969 [ Mon May 08, 2017 11:11 pm ] |
The mk1-forum spoke about these senders. http://mk1-forum.net/viewtopic.php?f=3&t=9515 According to AKD3509, the change from the senders retained by screws to those retained by a lock ring was at body no 23174 (in February 1964?). The lock-ring senders initially had the same stud & nut electrical connections as the earlier screw-in type and were used with the same fuel gauge. In September 1964 a revised lock-ring sender with Lucas terminals was introduced along with a new fuel gauge and the change to voltage-stabilised instruments. |
Author: | flapper [ Mon May 08, 2017 11:30 pm ] |
gtogreen1969 wrote: The mk1-forum spoke about these senders. http://mk1-forum.net/viewtopic.php?f=3&t=9515 According to AKD3509, the change from the senders retained by screws to those retained by a lock ring was at body no 23174 (in February 1964?). The lock-ring senders initially had the same stud & nut electrical connections as the earlier screw-in type and were used with the same fuel gauge. In September 1964 a revised lock-ring sender with Lucas terminals was introduced along with a new fuel gauge and the change to voltage-stabilised instruments. The night is late ![]() Peter & Karen |
Author: | timmy201 [ Tue May 09, 2017 7:46 am ] |
Also some info here: http://www.somerfordmini.co.uk/eshop/in ... age&id=161 2A2163 SENDER UNIT, fuel gauge, screw-in type 1959-64. ARA959 SENDER UNIT, fuel gauge, locking ring type 1964; models without voltage stabilizer. XNB10007 SENDER UNIT, fuel gauge, locking ring type 1964-80; models with voltage stabiliser. Fuel gauges here: http://www.somerfordmini.co.uk/eshop/in ... page&id=83 My HYL2980 Morris 850 parts book only lists the first type & my March-April 64 car has the type with screws |
Author: | timmy201 [ Tue May 09, 2017 8:11 am ] |
John Sneddon's book has the changeover to the locking ring "Smiths Quick Fix" at car 49099 - June 1964 |
Author: | gtogreen1969 [ Tue May 09, 2017 8:49 am ] |
timmy201 wrote: John Sneddon's book has the changeover to the locking ring "Smiths Quick Fix" at car 49099 - June 1964 That would make sense as we were a few months behind UK changes. |
