https://ausmini.com/forums/
Clean inside of mini fuel tank.
https://ausmini.com/forums/viewtopic.php?f=2&t=95320
Author:  p7676 [ Tue May 02, 2017 5:28 pm ]
Post subject:  Clean inside of mini fuel tank.
I have had not much luck cleaning the inside of my fuel tanks .the petrol was in them for years I think it turns into shellac. Does not appear to be any rust in the tank. P767676
Author:  too_much_boost [ Tue May 02, 2017 6:16 pm ]
Post subject:  Re: Clean inside of mini fuel tank.
Tried soaking in white vinegar?
Author:  drmini in aust [ Wed May 03, 2017 8:39 am ]
Put some fine gravel in there, then shake, baby, shake.
Author:  too_much_boost [ Wed May 03, 2017 8:41 am ]
I used white vinegar and let it soak for a while to loosen it up then put a few handfuls of gravel in there. Seems to do a good job as far as I can see
Author:  Timbo [ Wed May 03, 2017 10:22 am ]
I did the one in my Traveller with Koala Kare degreaser, and a bunch of nuts threaded together on a string, with lots of shaking. That took out the small amount of varnish from dead fuel, then I de-rusted it with citric acid. It looked like new when it was finished.
Author:  Jenk [ Wed May 03, 2017 9:32 pm ]
POR 15 tank repair kit...I did both my tanks with this
http://www.ppcco.com.au/por19.html
Author:  micool [ Thu May 04, 2017 9:29 am ]
I used CLR in a tank that I had to clean not to long ago and it worked wonders.
