It is currently Mon Jul 21, 2025 9:10 pm
 Post subject: Help needed please
PostPosted: Wed Apr 19, 2017 4:15 pm
I picked up a range of engines, parts and cars over Easter which I am now regretting a little bit... Luckily I didn't cost me much to purchase them so I'm sure I will be able to off load what I don't need once my Van is on the road... The moving and storage was more of a headache..
There was a yellow 998 engine prefix 9YA that has a strange drive shaft coming off the gearbox. Can you help me identify what it is??
My only mini experience is the Mini K van I am restoring which has a magic wand so it's a little different to start with..
 Post subject: Re: Help needed please
PostPosted: Wed Apr 19, 2017 4:20 pm
That is called a "Pot Joint". Used on the Leyland Minis. The gearbox is a rod change.
PostPosted: Wed Apr 19, 2017 4:42 pm
A Mini K should not have a "magic wand" gear shift as far as I know? Should be a remote gearbox with a short gear stick?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Apr 19, 2017 5:04 pm
Mini K Van would have a 4 sync "pudding stirrer", which uses the same diff housing as the remote but has a long gear lever
Pictures here:
viewtopic.php?f=9&t=76578
PostPosted: Wed Apr 19, 2017 5:34 pm
A Mini K poverty pack would also have a pudding stirrer.
PostPosted: Wed Apr 19, 2017 9:08 pm
That explains it, thanks.
My van is definitely the pov pack, very basic but it adds to the charm.
PostPosted: Thu Apr 20, 2017 8:23 am
You can use the pot joints instead of the rubber unis. Less breakages and cheaper bits. Not sure what exact bits you need though.
Sent from my SM-G900I using Tapatalk
PostPosted: Thu Apr 20, 2017 8:35 am
Output shafts, pot joints and driveshafts. Eg:
http://minikingdomonline.com.au/product ... pot-joint/
PostPosted: Thu Apr 20, 2017 3:46 pm
It might be worthwhile for the next project.
Did all clubmans have them?
PostPosted: Thu Apr 20, 2017 4:03 pm
Only later ones. Definitely a better joint. I'll be swapping when I get around to pulling the motor
PostPosted: Sat Apr 22, 2017 9:32 am
"Clubmans" had rubber uni-loints & 4-sync extension housing (remote) shifters,,,
"Leyland minis" (Later clubman "SHAPE" minis) all had pot joints with rod-change gearboxes
1973-1974 was a bit of a hodge-podge , cross-over between the 2 types, they could have any combination really
"plus" the poverty pack minis were the cheaper version, often having earlier stuff,,, & then there`s the last 40 plus years of other people swapping stuff around as they play with them :-)
just saying :-)
PostPosted: Sat Apr 22, 2017 4:53 pm
Yeah its all over the place. Mine is a povo same as most early vans. But the rubber unis are just a bust waiting to happen.
Users browsing this forum: fuzzy-hair-man and 68 guests
