Help needed please https://ausmini.com/forums/viewtopic.php?f=2&t=95247 |
Author: | Humphrey78 [ Wed Apr 19, 2017 4:15 pm ] |
Post subject: | Help needed please |
I picked up a range of engines, parts and cars over Easter which I am now regretting a little bit... Luckily I didn't cost me much to purchase them so I'm sure I will be able to off load what I don't need once my Van is on the road... The moving and storage was more of a headache.. There was a yellow 998 engine prefix 9YA that has a strange drive shaft coming off the gearbox. Can you help me identify what it is?? My only mini experience is the Mini K van I am restoring which has a magic wand so it's a little different to start with.. |
Author: | gtogreen1969 [ Wed Apr 19, 2017 4:20 pm ] |
Post subject: | Re: Help needed please |
That is called a "Pot Joint". Used on the Leyland Minis. The gearbox is a rod change. |
Author: | deluxe67 [ Wed Apr 19, 2017 4:42 pm ] |
A Mini K should not have a "magic wand" gear shift as far as I know? Should be a remote gearbox with a short gear stick? |
Author: | timmy201 [ Wed Apr 19, 2017 5:04 pm ] |
Mini K Van would have a 4 sync "pudding stirrer", which uses the same diff housing as the remote but has a long gear lever Pictures here: viewtopic.php?f=9&t=76578 |
Author: | TK [ Wed Apr 19, 2017 5:34 pm ] |
A Mini K poverty pack would also have a pudding stirrer. |
Author: | Humphrey78 [ Wed Apr 19, 2017 9:08 pm ] |
That explains it, thanks. My van is definitely the pov pack, very basic but it adds to the charm. |
Author: | bluehishouse [ Thu Apr 20, 2017 8:23 am ] |
You can use the pot joints instead of the rubber unis. Less breakages and cheaper bits. Not sure what exact bits you need though. Sent from my SM-G900I using Tapatalk |
Author: | timmy201 [ Thu Apr 20, 2017 8:35 am ] |
bluehishouse wrote: You can use the pot joints instead of the rubber unis. Less breakages and cheaper bits. Not sure what exact bits you need though. Sent from my SM-G900I using Tapatalk Output shafts, pot joints and driveshafts. Eg: http://minikingdomonline.com.au/product ... pot-joint/ |
Author: | Humphrey78 [ Thu Apr 20, 2017 3:46 pm ] |
timmy201 wrote: bluehishouse wrote: You can use the pot joints instead of the rubber unis. Less breakages and cheaper bits. Not sure what exact bits you need though. Sent from my SM-G900I using Tapatalk Output shafts, pot joints and driveshafts. Eg: http://minikingdomonline.com.au/product ... pot-joint/ It might be worthwhile for the next project. Did all clubmans have them? |
Author: | bluehishouse [ Thu Apr 20, 2017 4:03 pm ] |
Only later ones. Definitely a better joint. I'll be swapping when I get around to pulling the motor Sent from my SM-G900I using Tapatalk |
Author: | TheMiniMan [ Sat Apr 22, 2017 9:32 am ] |
"Clubmans" had rubber uni-loints & 4-sync extension housing (remote) shifters,,, "Leyland minis" (Later clubman "SHAPE" minis) all had pot joints with rod-change gearboxes 1973-1974 was a bit of a hodge-podge , cross-over between the 2 types, they could have any combination really "plus" the poverty pack minis were the cheaper version, often having earlier stuff,,, & then there`s the last 40 plus years of other people swapping stuff around as they play with them ![]() just saying ![]() |
Author: | bluehishouse [ Sat Apr 22, 2017 4:53 pm ] |
Yeah its all over the place. Mine is a povo same as most early vans. But the rubber unis are just a bust waiting to happen. Sent from my SM-G900I using Tapatalk |
