It is currently Mon Jul 21, 2025 9:11 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Feb 11, 2017 4:14 pm
Well, today I finally got around to assembling a new set of plug leads using four new old stock WC 187 Champion plug caps. These suckers cost twice as much as my second Mini did in 1974!
However, they are period correct & are even featured in the engine bay pic of the 1967 Mini brochure, so I'm wrapt to finally have them! After I've finished showing 'em off, they'll be installed...
PostPosted: Sat Feb 11, 2017 5:06 pm
looks fantastic. where did you find them?
PostPosted: Sat Feb 11, 2017 5:30 pm
Very nice, love this kind of stuff.
1993 R32 Nissan Skyline GTR
PostPosted: Sat Feb 11, 2017 5:39 pm
These came from Japan, & I reckon that the Japanese were savvy enough to stock up on as much BLMC stuff as they could while it was still available. - I also bought a pair of genuine NOS Cooper S over riders from the same company, "Dinky Incorporation", they were still in the original Elastoplast tape protection material & made of the much thicker, better fitting steel than the aftermarket ones.
Those were not cheap either, but saved a lot more searching around!
I think he (Naoki) may still have access to some more WC 187 Caps via the Japanese parts network..
PostPosted: Sun Feb 12, 2017 5:24 am
Me too.
I know this subject has come up before but can we have some photo's of what people think is the correct spark plug caps for Australian mini's incluing the Clubman GT.
I've seen a number of photo's but I'm still unsure of the correct cap for the year of each model.
Nothing like a chat about original detailing in engine bays :-)
Lots of photo's,Models and year of manufacture.
PostPosted: Sun Feb 12, 2017 5:36 pm
All of the early Australian Mini parts books list part 8G576 as the cap, with 12A365 sleeve and 7H6894 clip. I can't find a picture of 8G576 but assume it's the one shown at the start of this thread - Champion WC187 that Phillb has shown us in another thread.
Here are two photos of a GT engine bay. One is from the crash test photo that appears to be a late rather than early model (with the four-way breather). The other is part of an article in Australian Country magazine dated Feb 1972, so may be a prototype or press/demo model. Since they are both the same cap it would be a safe guess that it was used during most of the GT production.
The Mark II Cooper S certainly had the solid plastic numbered cap like the photo below of my 1970 car. I don't know when they began or ended.
PostPosted: Sun Feb 12, 2017 9:36 pm
Nice work.
Are you going to plug them onto Champion N9Y's ?
PostPosted: Mon Feb 13, 2017 6:10 pm
The Green Spark Plug Company make a very good replica of these , they have the green HT cable and other fittings as well
http://www.gsparkplug.com/catalogsearch ... 4T&q=wc187
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Mon Feb 13, 2017 9:02 pm
I tried there (Green Spark Plug Co.) & they were out of stock, mores the pity..
PostPosted: Thu Feb 16, 2017 12:48 pm
These guys have various versions of leads and caps.
http://www.ebay.com.au/sch/mr-retro-lea ... 7675.l2562
PostPosted: Mon Feb 20, 2017 12:47 pm
Mine arrived today!
PostPosted: Mon Feb 20, 2017 4:01 pm
For those using the repo of the rubber type shown a the beginning of this thread you will find a modern 90deg clip as pictured will fit inside with a bit of lube. This makes far better connection than the spike type one that often comes with old caps. Also be aware the metal sealing ring clip is not usually included, regardless BMC used a rubber sleeve instead. It's worth fining an auto election with the tool for fitting these, does a nice neat secure job.
PostPosted: Mon Feb 20, 2017 4:40 pm
Here's a shot of a Mark 1 Cooper S power plant being hot run tested in the Zetland plant prior to installation in a vehicle. I've cropped the image around the spark plugs although it's not particularly clear, unfortunately. I think I can make out Champion rubber plug caps like those in the picture that started this thread. As phillb has mentioned they don't have the metal rings.
PostPosted: Mon Feb 20, 2017 5:28 pm
Now just have to google how to put them on the leads ..
PostPosted: Mon Feb 20, 2017 6:50 pm
Thanks Doug. I was trying to get a close up of the yellow number tags.
Looks like the numbers are at right angles to the lead and the original yellow tags are wider than the ones supplied these days.
Users browsing this forum: fuzzy-hair-man and 73 guests
