Carby removal https://ausmini.com/forums/viewtopic.php?f=2&t=95233 |
Author: | mtodd [ Sun Apr 16, 2017 3:56 pm ] |
Post subject: | Carby removal |
Is there a special type of Spanner required to remove the bottom bolt fixing the carby to the manifold? I've had this off before so maybe it's just a lack of caffeine not allowing me to think straight. |
Author: | peterb [ Sun Apr 16, 2017 4:01 pm ] |
Post subject: | Re: Carby removal |
a small one. ![]() |
Author: | mtodd [ Sun Apr 16, 2017 4:51 pm ] |
Small and bent? |
Author: | goodie [ Sun Apr 16, 2017 6:31 pm ] |
Stubby spanner , or an old 1/2" ring /openender ground down ![]() |
Author: | mtodd [ Sun Apr 16, 2017 7:15 pm ] |
Thanks peterb and goodie. I'll give a stubby Spanner a go. I was sure it was a 9/16 size though. |
Author: | i got a mini [ Sun Apr 16, 2017 7:27 pm ] |
nah they are 1/2" well mine are |
Author: | Morbo28 [ Sun Apr 16, 2017 7:58 pm ] |
For one of the nuts in my setup...Take out speedo and undo it from the passenger seat ![]() I'm sure this doesn't help answer your question and for that I apologise. Sent from my Nexus 6P using Tapatalk |
Author: | BBY755 [ Sun Apr 16, 2017 10:22 pm ] |
That's the beauty of working on minis.....you gotta remove various unrelated parts to access and remove the one you want.......... ![]() |
Author: | sitnlo62 [ Sun Apr 16, 2017 10:29 pm ] |
mtodd wrote: Thanks peterb and goodie. I'll give a stubby Spanner a go. I was sure it was a 9/16 size though. If its a 1 1/4" carb it is 9/16" AF that's required 1 1/2" Carb uses smaller stud so 1/2" AF |
Author: | Fallingbrick [ Tue Apr 18, 2017 9:23 pm ] |
The original early Haynes manual recommends cutting the correct sized spanner (er, but not lengthways) in half for this job. |
Author: | AEG163job [ Tue Apr 18, 2017 9:44 pm ] |
BBY755 wrote: That's the beauty of working on minis.....you gotta remove various unrelated parts to access and remove the one you want.......... ![]() Try working on a Mk2 Jag and see how easy jobs are. Mini's are a soda. The only easy job on a Mk2 is removing/replacing wheels (Knock off wires). Everything else is a PITA. Yes, I was stupid to buy one. |
Author: | mtodd [ Tue Apr 18, 2017 9:47 pm ] |
Thanks everyone. I've had the carby off before but for the life of me can't remember how I did it. I'll buy a cheap Spanner and butcher and bend it if I have to. |
Author: | MiniBrad [ Fri Apr 21, 2017 7:00 pm ] |
AEG163job wrote: BBY755 wrote: That's the beauty of working on minis.....you gotta remove various unrelated parts to access and remove the one you want.......... ![]() Try working on a Mk2 Jag and see how easy jobs are. Mini's are a soda. The only easy job on a Mk2 is removing/replacing wheels (Knock off wires). Everything else is a PITA. Yes, I was stupid to buy one. It seems to be most English cars are like that. Brad |
