Wiring up a new starter solenoid https://ausmini.com/forums/viewtopic.php?f=2&t=95158 |
Author: | gtogreen1969 [ Tue Apr 04, 2017 10:39 pm ] |
Post subject: | Re: Wiring up a new starter solenoid |
I goes back onto the same post as the battery 12V lead with the other 2 wires. A new terminal connector with 1 large and 1 small male spade should have come with the new solenoid or just cleanup and reuse the old one it was originally plugged into. That extra terminal on the 4 terminal solenoid is used as a 12V bypass for a ballast ignition system. Here is some info on it - https://www.autoelectricsupplies.co.uk/product/1111 Attachment: ballast_res_large.jpg
Author: | shnitzee [ Wed Apr 05, 2017 3:42 pm ] |
Thanks guys. Will investigate further. Eiles |
