It is currently Mon Jul 21, 2025 10:13 pm
 Post subject: Wand shift boot
PostPosted: Fri Mar 31, 2017 3:01 pm
I cant work out what way the shifter boot goes on the wand shift. Theres a moulded steel band that holds the boot to the shape of the floor but does it fix from inside or out? It fits inside but would let water collect between the body and the boot. i need pics!
Sent from my SM-G900I using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
 Post subject: Re: Wand shift boot
PostPosted: Fri Mar 31, 2017 5:32 pm
Boot goes on top of tunnel and the retainer on top of that.
PostPosted: Fri Mar 31, 2017 6:08 pm
Thanks for that doc So what goes underneath? Hopes and dreams? Or gaffa tape?
PostPosted: Fri Mar 31, 2017 7:41 pm
Contact adhesive, Selleys Kwikgrip or similar.
PostPosted: Fri Mar 31, 2017 7:51 pm
That's how they were back then. Rubber over the hole, steel retainer on top. Underfelt and carpet/vinyl over the top. Just a good seal to keep the elements out. Bugger all gets in there anyway.
PostPosted: Fri Mar 31, 2017 8:00 pm
I hope not.. Might throw some body seal around the edges anyway. Cheers for that
