Diff Preload https://ausmini.com/forums/viewtopic.php?f=2&t=95088 |
Author: | IndigoBlueCooperS [ Wed Mar 22, 2017 7:47 pm ] |
Post subject: | Diff Preload |
I am setting up the diff preload and find I need extra shims to get the pre-load - 4thou for thrust bearings. I suspect the new gaskets are thicker than the old ones, and I am short on shims. Any issues leaving the side gaskets out and use RTV sealant instead? |
Author: | drmini in aust [ Thu Mar 23, 2017 5:32 am ] |
Post subject: | Re: Diff Preload |
My car has no side gaskets and doesn't leak there. But don't use RTV, use an anaerobic flange sealant designed for this. Loctite 515 or 518. |
Author: | RNY997 [ Thu Mar 23, 2017 11:52 am ] |
IndigoBlueCooperS wrote: I am setting up the diff preload and find I need extra shims to get the pre-load - 4thou for thrust bearings. I suspect the new gaskets are thicker than the old ones, and I am short on shims. Any issues leaving the side gaskets out and use RTV sealant instead? just buy some shims? |
Author: | timmy201 [ Mon Mar 27, 2017 6:44 pm ] |
I've read that Rover dropped the gaskets in later years and just used sealant. |
