Tacho problem https://ausmini.com/forums/viewtopic.php?f=2&t=95043 |
Author: | wendy [ Wed Mar 15, 2017 11:51 am ] |
Post subject: | Tacho problem |
I have just replaced the wooden dash with the origional binicle on my mark 2. I also placed the tacho in front of the steering wheel. However I am getting electrical interference, ie it pulses with the electrical pump and drops to zero when the lights are on. I sourced the power for the tacho from the terminals behind the speedo. Could that block be faulty. I also tryed a lead direct from the coil but still the same? any ideas please. |
Author: | DavidE [ Wed Mar 15, 2017 1:26 pm ] |
Post subject: | Re: Tacho problem |
Have you connected the 12v wire (+ve) to the 10v terminal on the thing you call the "block" (it's the voltage regulator)? The 10v terminal is labelled "I" whereas the 12v terminal is "B". |
Author: | wendy [ Wed Mar 15, 2017 4:05 pm ] |
Thank you, I will check that |
Author: | simon k [ Thu Mar 16, 2017 8:48 am ] |
and check your earth for the tacho |
Author: | wendy [ Fri Mar 17, 2017 6:42 am ] |
It was a wire earthing within the tacho. Thank you. Ian |
