Correct K&N air filter for 77 clubby https://ausmini.com/forums/viewtopic.php?f=2&t=95033 |
Author: | MINImal effort [ Tue Mar 14, 2017 5:43 pm ] |
Post subject: | Re: Correct K&N air filter for 77 clubby |
It's what MiniSpares list as suitable for a HS4. (which is standard for 77 Clubby) http://www.minispares.com/product/Classic/Filters/Air/E2601.aspx |
Author: | shnitzee [ Tue Mar 14, 2017 7:58 pm ] |
Thanks minimal Im just wondering if the smaller surface area would lessen its advantage over the standard (and larger) filter. Eiles |
Author: | MINImal effort [ Tue Mar 14, 2017 9:28 pm ] |
I've not used that style k&n so hard to say. The hs4 air filter housing is much larger than the hs2 - so in comparison has a much larger area to start with. My first mini was 77LS with a hs4 .... as I drove it home thought I'd got a lemon - struggled to do 90kmh. Changed the air filter and basic service and then capable of over 110kmh. My other minis have had twin Su and replaced with k&n - never had any issues and being re-usable have paid off over time. The version for the twin HS4 is probably a smaller filter area vs this style. Many will argue paper is better if the quality is good ; but is highly variable even from same manufacturer. K&n at least have a high quality. Many web articles out there claiming to show superiority of one over the other .... |
Author: | shnitzee [ Wed Mar 15, 2017 10:31 am ] |
Thanks minimal. I'll give it a go. Im trying to get the best out of the clubby with small upgrades until i can afford the bigger ones. ![]() Cheers Eiles |
Author: | jprior2912 [ Sat Mar 18, 2017 1:57 pm ] |
shnitzee wrote: Thanks minimal. I'll give it a go. Im trying to get the best out of the clubby with small upgrades until i can afford the bigger ones. ![]() Cheers Eiles Use a Ramflo filter over the K&N... I had K&N's on my Twin HS4 setup and switched to Ramflo's, noticed it was a bit perkier, the K&N's can be a little restrictive. James |
Author: | 1071 S [ Sun Mar 19, 2017 7:30 pm ] |
K&Ns are a premium product..and like any specialist item are not fit and forget. The main issue is that to work properly they need the correct oil applied in the correct amount... Too little and they don't filter as well, too much and they clog up... Its not too hard. Do it right and their about as good as you can get. Cheers, Ian |
Author: | timmy201 [ Sun Mar 19, 2017 8:41 pm ] |
I've got this one on my car (as part of a minispares kit) and works well. It should be overkill for a reasonably standard 998. If it flows more air than the factory style paper filter you might need to adjust the tune a little. I just make sure it isn't covering the throat to the carb when installing (it's a metal filter box) ![]() |
Author: | shnitzee [ Sun Mar 19, 2017 10:07 pm ] |
Thanks for the replies guys. I've bought one (came pre-oiled) so will see how it goes. Cheers Eiles |
