It is currently Fri Jul 18, 2025 5:55 pm
PostPosted: Mon Mar 13, 2017 11:25 pm
Hi all
I'm looking to replace the standard air filter on my clubby for a K&N one. Is E2601 the correct one? It has a smaller diametre to what is in the clubby at the mo.
Thanks
Eiles
PostPosted: Tue Mar 14, 2017 5:43 pm
It's what MiniSpares list as suitable for a HS4. (which is standard for 77 Clubby)
http://www.minispares.com/product/Classic/Filters/Air/E2601.aspx
PostPosted: Tue Mar 14, 2017 7:58 pm
Thanks minimal
Im just wondering if the smaller surface area would lessen its advantage over the standard (and larger) filter.
Eiles
PostPosted: Tue Mar 14, 2017 9:28 pm
I've not used that style k&n so hard to say.
The hs4 air filter housing is much larger than the hs2 - so in comparison has a much larger area to start with.
My first mini was 77LS with a hs4 .... as I drove it home thought I'd got a lemon - struggled to do 90kmh. Changed the air filter and basic service and then capable of over 110kmh.
My other minis have had twin Su and replaced with k&n - never had any issues and being re-usable have paid off over time.
The version for the twin HS4 is probably a smaller filter area vs this style.
Many will argue paper is better if the quality is good ; but is highly variable even from same manufacturer. K&n at least have a high quality. Many web articles out there claiming to show superiority of one over the other ....
PostPosted: Wed Mar 15, 2017 10:31 am
Thanks minimal.
I'll give it a go. Im trying to get the best out of the clubby with small upgrades until i can afford the bigger ones. :)
Eiles
PostPosted: Sat Mar 18, 2017 1:57 pm
shnitzee wrote:
Thanks minimal.
Eiles
Use a Ramflo filter over the K&N... I had K&N's on my Twin HS4 setup and switched to Ramflo's, noticed it was a bit perkier, the K&N's can be a little restrictive.
James
PostPosted: Sun Mar 19, 2017 7:30 pm
K&Ns are a premium product..and like any specialist item are not fit and forget.
The main issue is that to work properly they need the correct oil applied in the correct amount... Too little and they don't filter as well, too much and they clog up...
Its not too hard. Do it right and their about as good as you can get.
Cheers, Ian
PostPosted: Sun Mar 19, 2017 8:41 pm
I've got this one on my car (as part of a minispares kit) and works well. It should be overkill for a reasonably standard 998. If it flows more air than the factory style paper filter you might need to adjust the tune a little.
I just make sure it isn't covering the throat to the carb when installing (it's a metal filter box)
PostPosted: Sun Mar 19, 2017 10:07 pm
Thanks for the replies guys.
I've bought one (came pre-oiled) so will see how it goes.
Eiles
Users browsing this forum: No registered users and 116 guests
