https://ausmini.com/forums/
Light switch qu
https://ausmini.com/forums/viewtopic.php?f=2&t=95020
Author:  mooman10_0 [ Sun Mar 12, 2017 6:16 pm ]
Post subject:  Light switch qu
Am fitting new loom to my moke, have dash all layed out just wondering which colour wire goes to which terminal on the rocker light switch? I have brown, blue, and red. The switch has three terminals, (looking from the back, one by itself on the right and two ( one above tbe other) on the left. Anyone know what goes where, i have the rest sorted.
Steve
Author:  i got a mini [ Mon Mar 13, 2017 8:56 am ]
Post subject:  Re: Light switch qu
The back of the switch has numbers on it telling you which wire goes we're look at your wiring diagram it will have the wire going to the certain. Number :) hope this helps
Author:  winabbey [ Mon Mar 13, 2017 9:15 am ]
According to the wiring diagram in the Mini workshop manual:
Brown is the power feed from the fuse block on goes on terminal 3
Red is the side lights output on terminal 2
Blue goes to the dip switch and is on terminal 1
If I were you I'd connect the brown wire first, then use a multimeter to check output on the other switch terminals with the switch in each position.
Author:  Convertible Mini [ Tue Mar 14, 2017 12:18 pm ]
And if you want better lights and switches to last fit and wire some relays. Amen.
