It is currently Tue Jul 22, 2025 10:48 am
PostPosted: Sun Mar 12, 2017 4:02 pm
Can some one advise any information regards the wing nut that holds the rear seat cushion to the seat pan in the Australian mini.
The parts manual PUB 1056M states N.L.A. with no other detail so looking for a photo and some detail regards thread and size etc, or even better some for sale. :-)
PostPosted: Sun Mar 12, 2017 4:42 pm
Mine is missing the wingnuts as well. I haven't looked at what thread they are yet.
PostPosted: Sun Mar 12, 2017 5:35 pm
Thankfully I have a jar of them. Take your seat squab to a fastener shop and get matching wing-nuts from their stock.
PostPosted: Sun Mar 12, 2017 5:51 pm
The wing nut and washer is listed here. I'll keep an eye out for anything further.
PostPosted: Sun Mar 12, 2017 6:30 pm
Thanks Doug.
I've been hunting around but with no luck as yet.
Would you have a picture by any chance? :wink: :wink:
Pete.
PostPosted: Sun Mar 12, 2017 6:32 pm
If I come across any I'll let you know :)
PostPosted: Sun Mar 12, 2017 6:41 pm
Can you re-attach the thread to the seat? Is it replaceable? Mine is one short.. As for the wingnut, at some point the thread changed as my 78 ones didn't fit the 71
Sent from my SM-G900I using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Sun Mar 12, 2017 6:44 pm
In the later Clubman parts book the wing nut supercedes to part SYN29.
According to the BMC Standard for unified wing nuts, SYN29 is a No 10 (.19") UNF thread zinc alloy die cast wing nut in plain finish.
I have two rear seat cushions with all four wing nuts and washers missing, which I can understand. The cushion is a friction fit and usually stays in place without wing nuts once the two little bolts are in their holes.
PostPosted: Sun Mar 12, 2017 7:41 pm
Bunnings? That's where I got mine. 3/16" unc
PostPosted: Sun Mar 12, 2017 7:48 pm
I didn't know there were meant to be wingnuts.... never ever seen them
Ok. So they are 3/16 UNC. Thanks
PostPosted: Mon Mar 13, 2017 7:34 am
Cheers Peterb
Will check that out. :wink:
PostPosted: Mon Mar 13, 2017 7:42 am
3/16W also fits. Same pitch as UNC.
PostPosted: Mon Mar 13, 2017 1:47 pm
No I don't think so!
Every seat I have ever seen has had #10/32 unf threads sometimes incorrectly referred to as 3/16 unf
#10/32 in very common thread used on a Mini and all BMC cars of the era.
PostPosted: Mon Mar 13, 2017 1:55 pm
Ok. So they are not 3/16 UNC as peterb said. Thanks
Users browsing this forum: Steam and 85 guests
