Rover Mini Gauge Cluster into Leyland? https://ausmini.com/forums/viewtopic.php?f=2&t=94951 |
Author: | RetroStyle [ Sun Feb 26, 2017 11:44 am ] |
Post subject: | Rover Mini Gauge Cluster into Leyland? |
Hi all, Opportunities present themselves from time to time, and before I shop I would like to know if it is an east swap. I have a 77 Leyland Mini with the original 3 gauge cluster. Would the a Rover Mini cluster (such as is pictured below) be plug and play? Appreciate your thoughts. David. |
Author: | peterb [ Sun Feb 26, 2017 2:22 pm ] |
Post subject: | Re: Rover Mini Gauge Cluster into Leyland? |
I think only the tacho wiring is different, if its out of MPI. easy way to check the rest is put the two side by side and follow the circuit 'tracks'. |
Author: | Harley [ Sun Feb 26, 2017 2:40 pm ] |
Coil pack minis ran a different tacho signal, though the rest is very much the same. |
Author: | RetroStyle [ Sun Feb 26, 2017 3:08 pm ] |
Harley wrote: Coil pack minis ran a different tacho signal, though the rest is very much the same. Thanks guys. Can the signal be converted? Sent from my ASUS_Z017DA using Tapatalk |
Author: | westham0 [ Sun Feb 26, 2017 5:21 pm ] |
I have the dash from a late MPI Rover mini in my LS and it works fine. I can't remember for sure as it was some time ago but I think if you remove the tachometer there is an adjustment screw that can be turned tune it to your requirements. I think I connected up another tachometer seperate and adjusted the Rover one to read the same as it. I can't saw its 100% accurate but I believe it to be pretty close. |
Author: | i got a mini [ Sun Feb 26, 2017 7:20 pm ] |
how did u get the fuel and temp gauge to work as there is no voltage stabilizer ?? |
Author: | KLAS [ Sun Feb 26, 2017 9:23 pm ] |
i got a mini wrote: how did u get the fuel and temp gauge to work as there is no voltage stabilizer ?? it's build inside of the Rover/Nippon Seki gauges |
Author: | i got a mini [ Mon Feb 27, 2017 6:55 pm ] |
Ahhhh that makes sense go for it ![]() |
Author: | RetroStyle [ Wed Mar 01, 2017 11:57 am ] |
Thank you all for your replies. Apart from Tacho calibration - all seems plug'n'play. Cheers, David |
