FirstMini wrote:
Hello all, I'm in central Vic and have had two minis in the shed that have been waiting for me to mate them together for too long. A Leyland with a 1275 with a bit of a cam by the sound of it, and large dent behind drivers door and a Morris that's been in primer since painted by the previous owner maybe 20 years ago but seems to be rust free. Unfortunately he was a fan of black jack sound deadener and has painted the engine bay and interior to speedo level with it. I was a mechanic for about 18 years but avoided Minis so will have many questions when the work begins which will be soon as I'm running out of bikes to restore. Just a couple for now, where should I go for parts? The car has hydro suspension that's not leaking, should I just leave it alone? Does the standard speedo fit OK into the three hole unit? Thanks for now, Jonesy.
Welcome Jonesy,
Re the Hydro, if you have the time and inclination then stripping the front and rear suspension might be a good thing to do just for peace of mind and to ensure everything is right...even just flushing and re-pressurising the system might be worthwhile after checking all the lines for corrosion etc
Enjoy! Mick
