It is currently Wed Jul 23, 2025 10:40 am
PostPosted: Sun Feb 19, 2017 10:56 pm
Hi guys, I'm not happy with my rear window rubber, its just doesn't seem to fit properly..
Its almost as if the Rear Window rubber is to skinny and doesn't go upto the edge of the pressed section if that makes sense, its almost as if my rear window is bigger ( its not) just the current rubber is to thin...
Cheers Brett
PostPosted: Mon Feb 20, 2017 5:38 am
you could try a few windscreen places or clark rubber, the rubber is quite common shape used in many aplications. Different brands may vary slightly. Other than that you might want to look at Rover screen mould, theyre wider. Cut to length.
PostPosted: Mon Feb 20, 2017 4:00 pm
Check that the rubber has not been put in the wrong way. This will make it look like that!
1965 MK1 English Morris Cooper S (Downton)
1967 MK1 Morris Cooper S
1972 Clubman GT (6/72 Cadiz)
1968 MG Midget
Users browsing this forum: wild_willy and 100 guests
