It is currently Wed Jul 23, 2025 12:00 am
 Post subject: subframe dimensions
PostPosted: Fri Feb 17, 2017 6:36 pm
Die Die Die!!
can anyone tell me what the dimensions of a standard mini subframe are ?
L x W x H ?
also a rough estimate of weight ?
Thanks
 Post subject: Re: subframe dimensions
PostPosted: Sat Feb 18, 2017 8:58 pm
PostPosted: Sun Feb 19, 2017 4:48 am
Die Die Die!!
That's a start.. but it doesn't provide the outer most dimensions for the front frame, outside of the tower to the outside of the tower..
I'm trying to post one...
PostPosted: Sun Feb 19, 2017 10:01 am
980mm wide x 680mm long x 40mm high,
Weight of a bare frame with no arms or fasteners is 17.5kg.
PostPosted: Sun Feb 19, 2017 10:39 am
Die Die Die!!
Cheers :)
