It is currently Wed Jul 23, 2025 7:26 am
 Post subject: Re: LCB Header Bracket
PostPosted: Mon Feb 13, 2017 11:50 am
Attaches to the side cover bolt at rear lower bolt. you will have to bend it to fit or make another bracket to bolt them together
PostPosted: Mon Feb 13, 2017 4:08 pm
Yes, the bottom one.
PostPosted: Mon Feb 13, 2017 5:27 pm
I would suggest you look for the bracket sold by some of the usual suspects that attaches to at least 2 of the flange bolts... Your exhaust tab then attaches to this bracket. (or make one ?)
I have found the single bolt inadequate at times to withstand the forces the exhaust can apply. The thread in the alloy diff casting will eventually give up...
Cheers, Ian
Users browsing this forum: acarseldine, Bing [Bot], Nev, Wolfgang and 97 guests
