It is currently Wed Jul 23, 2025 12:03 am
 Post subject: Re: LCB Header Bracket
PostPosted: Mon Feb 13, 2017 11:50 am
Attaches to the side cover bolt at rear lower bolt. you will have to bend it to fit or make another bracket to bolt them together
PostPosted: Mon Feb 13, 2017 4:08 pm
Yes, the bottom one.
PostPosted: Mon Feb 13, 2017 5:27 pm
I would suggest you look for the bracket sold by some of the usual suspects that attaches to at least 2 of the flange bolts... Your exhaust tab then attaches to this bracket. (or make one ?)
I have found the single bolt inadequate at times to withstand the forces the exhaust can apply. The thread in the alloy diff casting will eventually give up...
Cheers, Ian
