It is currently Wed Jul 23, 2025 11:06 am
 Post subject: Subframe Differences ?
PostPosted: Fri Feb 17, 2017 6:45 pm
Die Die Die!!
if any what are the differences between 1960's subframes and 2000 subframes ?
the later ones had difference firewall brackets and also had the 2 large tower bolts,
the rear subframes i dont think were any different ?
Nick
PostPosted: Sat Feb 18, 2017 12:44 pm
The only thing with the rover frames coming to mind is if they are rubber mounted instead of metal on metal like the old.
PostPosted: Sat Feb 18, 2017 12:58 pm
Rear subframes are the same, possibly with the exception of some exhaust mounts on late cars. At some point Rover changed to a larger trunnion/bush at one end of the rear subframe, but these are interchangeable.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Sat Feb 18, 2017 4:09 pm
MPI front sub-frames had lower mounts for the radiator.
PostPosted: Sat Feb 18, 2017 6:52 pm
Die Die Die!!
looking at a picture i just saw, the rear subframe only has a 3 way splitter for the brakes on the later model rovers, and the earlier ones had a brake pressure regulator
PostPosted: Sat Feb 18, 2017 7:31 pm
Rear subframes are the same except for exhaust hangers welded onto frames originally fitted to injected cars.
A uk mk3 mini front subframe has different tower, front and rear mounts.
In the 80s a bracket was added to the front bar for a lower engine mount stabiliser.
In 97 the mounts were added for the front radiator.
PostPosted: Sat Feb 18, 2017 7:47 pm
Im pretty sure the later rovers have a single cable for the handbrake
PostPosted: Sat Feb 18, 2017 7:55 pm
Die Die Die!!
That's confirmed they do.. different hand brake mounts on the floor also
PostPosted: Sat Feb 18, 2017 8:03 pm
Subframe is no different because of the hand brake- the tabs on it are all the same.
I converted my deluxe to rover single cable handbrake it was easy and works heaps better than the original.
PostPosted: Sat Feb 18, 2017 8:16 pm
Die Die Die!!
How did you do that? I'd like to do that..
PostPosted: Sat Feb 18, 2017 9:13 pm
Just need the rover handbrake and cables.
Body mods are easy- just a single hole to drill in the top of the tunnel and make a small bracket to support back of handbrake. Easy.
Users browsing this forum: drmini in aust and 87 guests
