It is currently Wed Jul 23, 2025 12:02 am
 Post subject: Nissan distributer
PostPosted: Sat Feb 11, 2017 9:06 am
OK - starting to panic - the Mini HAS to be working for my sons wedding in 4 weeks so questions will come thick and fast as it is years since I has been working on it and I have forgotten what where and why I did some things.
Like the Nissan electronic distributer - two wires - one blue and one black with white trace - where do they go? also near the alternator there are three wires from the loom one white and two white with black trace what were these for? alternator is hooked up
 Post subject: Re: Nissan distributer
PostPosted: Sat Feb 11, 2017 9:23 am
white is ign power to the coil, so is the blue from the nissan dist, to the pos on coil (same terminal as the white)
white with black trace, is neg from coil to dist (also taco trigger),
so now it`s also the same as the black with white trace from nissan dist
PostPosted: Sat Feb 11, 2017 9:27 am
Thanks Matt -would have realised about the coil if it was installed :roll:
PostPosted: Sat Feb 11, 2017 9:48 am
WRONG!!
Blue is neg, black white is pos.
Get wrong and it burns out the module.
PS. I have fitted lots.
PostPosted: Sat Feb 11, 2017 11:57 am
Thanks Doc - makes more sense blue being equivalent to black in AC
