It is currently Wed Jul 23, 2025 8:44 pm
PostPosted: Mon Feb 06, 2017 12:55 pm
Apparently the windscreen washer bottle on the early production Mini Clubman vehicles was mounted on the radiator shroud, the one attached to the engine that supports the radiator. As a result it was subject to puncture by continual rubbing against the lower valance flange through engine movement.
Below is the factory issued instructions to Dealers to re-position the bottle on early cars in for routine servicing. I don't believe there was a recall as such.
I wonder how many of those early vehicles missed the re-work and still have the bottle in the original position?
PostPosted: Mon Feb 06, 2017 1:06 pm
Mine did. Still have the bottle and bracket but im putting an electric pump in now. It literally had 5mm clearance.
Sent from my SM-G900I using Tapatalk
