Scoop wrote:
Bill B wrote:
This is a brilliant little post. Thanks for the details. esp. the brands of gun and nozzle sizes.
I would be interested in some comments about mixing paint - esp. thinning to get good flow finish, as my efforts seem to get better if I use more thinners than recommended on paint containers.
Yeah sure Bill B we can cover this..
I will write something up explaining visco, additives and temp to help explain flow in regards to 1k.
and something for 2k to explain the gelling process of hardener. the slow, medium and fast are more about flow and work time. Nothing about how fast it dries.
It all depends on what products you use, temperature and application amount. Trial and error really, practice on something else before doing the important bits!!
Fully agree with this Scoop. So many times doing small samples until you are happy with the result is the only way to go.
AEG163job thanks for your input i have not brought a new compressor for a while so i was not sure if the new ones keep up a bit better.
I thought about covering some of the safety aspects of painting next week. I probably should of started there.
Then we will tackle flow and finish for Bill B
