It is currently Wed Jul 23, 2025 8:44 pm
 Post subject: Cooper S ride height
PostPosted: Wed Feb 01, 2017 6:10 am
What is the correct ride height for the Australian Cooper S with hyro suspension.
I understand there is a factory measurement to set the car at the correct height.
 Post subject: Re: Cooper S ride height
PostPosted: Wed Feb 01, 2017 9:10 am
The Scientific Publications/Gregory'sbook says 12 3/8 inches at front. The factory book says 12 5/16 inches (vertically) from wheel centre to wheel arch. Being hydro, you can set it wherever you prefer. Lower gives slightly better handling and higher gives softer ride.
I set height using 2 fingers held together then pushing them between tyre top and wheel arch. Judging how far in you can move your fingers gives a very accurate comparison side to side. The rear ride height can't be adjusted separately without removing the rear struts and shortening them as needed.
PostPosted: Wed Feb 01, 2017 2:34 pm
How phat are your fingers Bill :|
PostPosted: Wed Feb 01, 2017 5:44 pm
Yes I also use two fingers for the front height but don't cut the rear struts as you cant replace them. Proper fix is to install a washer between ball foot and front trumpet
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Feb 01, 2017 10:03 pm
I like to see the driveshafts close to horizontal, and trim the height accordingly.
Not sure if this theory is correct though.
However, I do know the plastic ball foot cups in the arms need to be in good nick.
PostPosted: Thu Feb 02, 2017 12:06 pm
They are within BMC General Data specifications and therefore always slightly too large to reach any component needing attention on a mini.
PostPosted: Thu Feb 02, 2017 4:50 pm
:D
