https://ausmini.com/forums/
Cooper S ride height
https://ausmini.com/forums/viewtopic.php?f=2&t=94782
Author:  Firefirey [ Wed Feb 01, 2017 6:10 am ]
Post subject:  Cooper S ride height
What is the correct ride height for the Australian Cooper S with hyro suspension.
I understand there is a factory measurement to set the car at the correct height.
Author:  Bill B [ Wed Feb 01, 2017 9:10 am ]
Post subject:  Re: Cooper S ride height
The Scientific Publications/Gregory'sbook says 12 3/8 inches at front. The factory book says 12 5/16 inches (vertically) from wheel centre to wheel arch. Being hydro, you can set it wherever you prefer. Lower gives slightly better handling and higher gives softer ride.
I set height using 2 fingers held together then pushing them between tyre top and wheel arch. Judging how far in you can move your fingers gives a very accurate comparison side to side. The rear ride height can't be adjusted separately without removing the rear struts and shortening them as needed.
Author:  9YaTaH [ Wed Feb 01, 2017 2:34 pm ]
How phat are your fingers Bill :|
Author:  michaelb [ Wed Feb 01, 2017 5:44 pm ]
Yes I also use two fingers for the front height but don't cut the rear struts as you cant replace them. Proper fix is to install a washer between ball foot and front trumpet
Author:  AEG163job [ Wed Feb 01, 2017 10:03 pm ]
I like to see the driveshafts close to horizontal, and trim the height accordingly.
Not sure if this theory is correct though.
However, I do know the plastic ball foot cups in the arms need to be in good nick.
Author:  Bill B [ Thu Feb 02, 2017 12:06 pm ]
They are within BMC General Data specifications and therefore always slightly too large to reach any component needing attention on a mini.
Author:  9YaTaH [ Thu Feb 02, 2017 4:50 pm ]
:D
