It is currently Wed Jul 23, 2025 10:55 am
PostPosted: Sun Jan 29, 2017 7:50 pm
Guy
Just picked up a Moke today.
The front left wheel is rubbing/extremely close to the shock.
Comparing sides it's about 10+mm gap on right side and basically 1mm to zero gap on left which rubs as soon as you go around a corner or hit a bump.
Any suggestions.
It's running a disc front end too.
Thanks
PostPosted: Mon Jan 30, 2017 10:22 am
Its pretty common for Moke front wheels to rub, usually they rub in the wheel arch. It doesn't happen when the suspension cones are new, but gets worse as they compress.
I'd be looking at why its different from side to side though. It might just bethatthe tyres are different, try swapping the wheels around, but otherwise I think everything probably needs measuring up to see what is different.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Jan 30, 2017 11:18 am
One side doesn't have a spacer? and the other does?
Nick
Users browsing this forum: slacko and 90 guests
