63 850 Front subframe Q https://ausmini.com/forums/viewtopic.php?f=2&t=94728 |
Author: | uqclint [ Thu Jan 26, 2017 1:42 pm ] |
Post subject: | 63 850 Front subframe Q |
Hi all, Car almost is stripped for blaster (Motor out)but the driver side subframe nuts on the mount studs on the towers are munted. I dont want to destroy the studs getting them out if the are a fixed part of the sub frame. If they are easily replaced when the subframe is out then I will just slice them off. Any advice? 54 years of brake and clutch fluid leaking all over them has made them very round. Cheers CK |
Author: | drmini in aust [ Thu Jan 26, 2017 2:00 pm ] |
Post subject: | Re: 63 850 Front subframe Q |
Cut them. They screw out. If you can't buy new ones they are not hard to make. |
Author: | uqclint [ Thu Jan 26, 2017 2:02 pm ] |
Cheers, the makita is ready to go. |
