It is currently Wed Jul 23, 2025 11:05 am
 Post subject: 63 850 Front subframe Q
PostPosted: Thu Jan 26, 2017 1:42 pm
Hi all,
Car almost is stripped for blaster (Motor out)but the driver side subframe nuts on the mount studs on the towers are munted. I dont want to destroy the studs getting them out if the are a fixed part of the sub frame. If they are easily replaced when the subframe is out then I will just slice them off. Any advice? 54 years of brake and clutch fluid leaking all over them has made them very round.
CK
PostPosted: Thu Jan 26, 2017 2:00 pm
Online
Cut them. They screw out. If you can't buy new ones they are not hard to make.
PostPosted: Thu Jan 26, 2017 2:02 pm
Cheers, the makita is ready to go.
Users browsing this forum: drmini in aust and 80 guests
