It is currently Wed Jul 23, 2025 8:46 pm
PostPosted: Sat Jan 28, 2017 10:47 am
Does anyone have the details on what speed nuts and screws were used to attach the fibre cover over the rot dip hole in the rear firewall? I need some.
1963 997 Morris Cooper
1964 Sunbeam Tiger
1969 Austin 1800
1969 Lancia Fulvia Rallye 1,3S
PostPosted: Sat Jan 28, 2017 11:51 am
I believe four Philips headed PK (self-tapper) screws were used. They simply screw into 4 of those doubled over spring clips that slide over the rear panel lined up with the 4 holes. Not sure what those clips are correctly called, but they are the same as the ones used to fix the radiator cowling.
I'm sure someone a lot smarter than me will post a photo.
PostPosted: Sun Jan 29, 2017 2:25 pm
AEG163job is right.
They are panhead/phillips 10gauge x 1/2 inch but with the point ground off (for safety?) since they point into the boot. I think they're the same as the 2 screws holding the boot latch on the top edge.
I can't find part numbers for either the speed nuts or self-tappers.
The speed nuts will probably be found in car parts shops on Champion parts "trees". They are 1/2 inch (12.7mm) wide x 13/16 inch (20mm) long with the hole right in the centre. And they ARE the same as the radiator speed nuts.... never noticed that before! P/n GHF713 $1.10 @ mini kingdom, etc.
PostPosted: Sun Jan 29, 2017 2:36 pm
Bill B wrote:
AEG163job is right.
Confirmed. GHF713 or GHF0713 as shown in my now very dated, but invaluable, Seven Enterprises catalogue and parts list. There's nothing special in the speednuts, just a normal automotive hardware item.
PostPosted: Sun Jan 29, 2017 6:26 pm
Thanks guys, most helpful.
1964 Sunbeam Tiger
1969 Austin 1800
PostPosted: Mon Jan 30, 2017 8:10 am
p.s. Mini Spares UK list and sell GHF713 but claim while they are popular, were never fitted to a mini (in UK)!
Users browsing this forum: BBY755, Bing [Bot] and 102 guests
