It is currently Wed Jul 23, 2025 11:04 am
 Post subject: fitting shocks to front
PostPosted: Wed Jan 25, 2017 6:32 pm
Hi All,
I'm trying to fit Gaz shocks to the front end... but the bottom shoulder of the shock fowls the bump stop mount/top arm, I'm guessing its not supposed to fit up close and that there might be a spacer or something I could use, I know that there is a stepped bolt made specifically for this modification but we decided it would be better to drill out the top arms and bump stop to 3/8 and fit a bolt instead. I guess the stepped bolt keeps the shock at the right distance away from top arm? Has anyone made this mod to wet suspension? How did you get around it? any advice appreciated.
Thanks.
Jenk
Jenk.
PostPosted: Wed Jan 25, 2017 8:43 pm
There should be a spacer on the bolt between the shocker and the bumpstop.
It is about 1/2 inch long.
Latter Mini's had a separate spacer on the bolt. Early ones had a special bolt with spacer built in.
PostPosted: Wed Jan 25, 2017 9:21 pm
I used a few thick washers.... top and bottom
PostPosted: Thu Jan 26, 2017 6:53 am
Bunnings spacers. :-) :-) :-)
PostPosted: Thu Jan 26, 2017 2:09 pm
Thanks guys... what about how the shock fowls the inner guard as per pic, is it just a matter of bending the guard inward?
Jenk.
PostPosted: Thu Jan 26, 2017 2:35 pm
Online
Yes.
PostPosted: Thu Jan 26, 2017 3:12 pm
going by your first photo, it looks like someone has bent it a fair way outwards anyway, it should be tight up against the subframe. The little hole in it should have had a little rubber buffer in it to stop it tapping on the subframe - I don't know if the pad was fitted at the factory, but that's what the hole is for
PostPosted: Thu Jan 26, 2017 7:22 pm
I ended up using some thick washers as Simonk did and bent the inner guard seams down... thanks all.
Jenk.
PostPosted: Thu Jan 26, 2017 10:12 pm
Hope you dont find the uprated shock too stiff ..its doubling up on the hydroelectric existing shock absorber function......
Cheers, Ian
PostPosted: Fri Jan 27, 2017 8:15 pm
Cheers, Ian
Hi,
If you mean Hydrolastic.... Its been converted to rubber cones.
Jenk.
PostPosted: Fri Jan 27, 2017 8:28 pm
Well, I always wondered what that hole was for.
Great, today has not been a dead loss - I have actually learned something new!
Users browsing this forum: drmini in aust and 83 guests
