https://ausmini.com/forums/
Dash removal 1978 Leyland mini van
https://ausmini.com/forums/viewtopic.php?f=2&t=94720
Author:  Jess_dela [ Wed Jan 25, 2017 5:13 pm ]
Post subject:  Dash removal 1978 Leyland mini van
Anyone able to help to say or show how to pull the dash off in my 1978 Leyland mini van
Author:  simon k [ Thu Jan 26, 2017 7:04 pm ]
Post subject:  Re: Dash removal 1978 Leyland mini van
which bit of the dash? the gauge cluster or the top pad?
haven't taken the dash pad off a clubman in 20 years, but there are 2 nuts to be removed at either end, accessed from underneath
Author:  Jess_dela [ Fri Jan 27, 2017 10:33 am ]
thanks Simon saw them needing more help now
Author:  mini_man_90 [ Fri Jan 27, 2017 11:16 am ]
Haven't done it myself, but from what I've seen posted in the past you benefit yourself by removing the windscreen to do this job
Author:  1071 S [ Fri Jan 27, 2017 1:52 pm ]
I agree about the windscreen... I think you can remove it with the windscreen in place but its a pretty brutal affair ripping it out past the rubber seal at the bottom of the screen. I'm pretty sure I removed the screen last time... (it was quite a while ago....).
Cheers, Ian
