https://ausmini.com/forums/
Air/Train horn install?
https://ausmini.com/forums/viewtopic.php?f=2&t=94704
Page 1 of 2
Author:  jprior2912 [ Mon Jan 23, 2017 10:05 am ]
Post subject:  Air/Train horn install?
Hi,
I'm a little tired of people not getting out the way when I need to beep my 'cute' original mini horn. I figure, maybe scaring the $h#t out of people will encourage them to not merge basically on top of me.
Has anyone install an air horn/train horn type horn in their mini? There's a big variety of them on ebay you can buy, so was possibly interested in one of those kits.
James
Author:  Hobson [ Mon Jan 23, 2017 10:19 am ]
Post subject:  Re: Air/Train horn install?
I have a nautilus style one in direct replacement of the stock horn. Works well, but the sound is a bit happy for my liking. I believe the db limit for a standard horn is 139 db. I don't see why you can't put a train horn in the rear sub frame for emergencies.
Author:  jprior2912 [ Mon Jan 23, 2017 10:40 am ]
Thanks, that Nautilus one seems it may be more practical than having trumpet style horns.
Was there much work to do wiring wise? At the moment I just have the two purple wires coming off the horn (not sure if they are relayed, would need to check)
Author:  Hobson [ Mon Jan 23, 2017 10:43 am ]
No wasn't much. I forget exactly but I think it's power to relay and horn. Which is the two purple then a new Earth and from the relay and a loop to the other end of the horn with a 15 amp fuse in an inline holder. I mounted the relay under the cross member in the second horn mounting hole.
Sent from my SM-G930F using Tapatalk
Author:  Matt I [ Mon Jan 23, 2017 10:53 am ]
I have a pair almost identical to this kit to be fitted to our Mini K that came off of a Clubman wreck:
http://www.ebay.com.au/itm/252476554519
They were on the inner guard behind the grille on the Clubman, and fit well behind the grille on the K, alongside the clutch housing (using existing holes for the original heater!).
Author:  timmy201 [ Mon Jan 23, 2017 10:58 am ]
This is from NSW EPA..
http://www.epa.nsw.gov.au/noise/vehiclenoise.htm
Noise from motor vehicle horns
Horns cannot be installed or used if they are louder than the level in clause 21 of the Regulation. This level is 120 decibels for noise made up of a single non-varying loudness and pitch or 85 decibels in any other case.
Police and Emergency Service vehicles are exempt.
Horns should be used as traffic warning devices only and not as a means of relieving driver stress or frustration.
Attaching a horn to a motor vehicle or permitting a motor vehicle to be used if it is fitted with a horn that is capable of emitting noise at a level greater than 120 dB(A) for noise at a single non-varying loudness and pitch, or 85 dB(A) in any other case (clause 21) $200 Fine
Author:  Irish Yobbo [ Mon Jan 23, 2017 12:09 pm ]
I also have a stebel nautilus horn and installed i similar to how jprior2912 installed theirs. However I had issues with the horn moving too much and it actually tore the sheet metal lip. I installed it further forward by moving the mounting point to the top of the horn and putting a small bolt through the bonnet catch panel, it's much more secure there.
But it's been a good horn, I really don't think it's the claimed 139dB but it is loud.
Author:  Hobson [ Mon Jan 23, 2017 2:06 pm ]
Interesting, i dunno where I pulled the 139 number from must be the 4 inch sound distance, most of the stables are under 120db at a 2m distance.
Author:  danny_ [ Mon Jan 23, 2017 4:00 pm ]
I had a 169db train horn installed in the moke,
Horns under the rear subframe and tank/ compressor in the side box.
I later transferred this to the mini, Tank and compressor in the boot with the horns where a brake booster normally sits.
Author:  peterb [ Mon Jan 23, 2017 6:03 pm ]
My bus horn is only 120db.......... measured at a one kilometre distance. :-) :-) :-) :-) :-)
Author:  Morbo28 [ Mon Jan 23, 2017 7:23 pm ]
I have the Steel Nautilus. From what I read too the horn noise limit is 120db and this one exceeds it at 139db. (Assuming that 139 is the correct amount as outlined in all of the marketing material)
Sent from my Nexus 6P using Tapatalk
Author:  1275LS [ Mon Jan 23, 2017 7:59 pm ]
I have a nautilus. It is plenty loud enough and an easy install.
I kept the original horn as well. :lol:
Author:  drmini in aust [ Tue Jan 24, 2017 10:15 am ]
I run a pair of Fiamm metal trumpet air horns rescued from my Fiat 124 Sport.
Installed in LH wheel arch they are plenty loud if leaned on, but give a polite beep if touched quickly.
Author:  Tonz [ Tue Jan 24, 2017 11:47 am ]
As a teenage hoon my mini had 2 sets of triple horns bolted onto roof. :evil: ,
When in a real nasty 'get out my way' mood a secret switch was flicked and when horn button pushed all horns came on plus 4 spotties, they whole thing had a separate battery and wiring in the boot.
I regretfully say I was a hoon and did not respect that little rocket, but if i had a mini today the above would still fit in just a little more subtle. Like scaring the crap out of idiots.
Author:  Lillee [ Tue Jan 24, 2017 2:18 pm ]
I have a Stebel Nautilous. Very compact and very loud
