It is currently Wed Jul 23, 2025 8:49 pm
PostPosted: Thu Feb 02, 2017 9:14 pm
Hi All,
I'm looking to buy a set of ignition leads, what are you all using? I like the look of the ones GR has on his website but he doesn't have any stock and I'm not sure if he's getting anymore in.
Ill be running the Pertronix 3.0 ohm 60000 volt flame thrower coil with a pulsar dizzy not sure what resistance etc will need to be.
thanks in advance.
Jenk.
PostPosted: Fri Feb 03, 2017 6:44 am
I used Bosch inductive core leads, hanging on the rack at Repco (or in Supercheap, if they ever replenish stock).
They have straight plug caps and 90 deg dizzy end caps.
Part numbers:
3x B35Ri,
1x B45Ri,
1x B30CRi (coil lead). For normal Mini coil positions.
I use a B60CRi, because my coil is on the RH inner guard behind the `matic heater. So it don't get wet. :wink:
The numbers above are length in cm.
These leads are all around 1.6-1.8 K ohm and don't deteriorate with age.
Users browsing this forum: BBY755, Bing [Bot] and 106 guests
