Standard 850 mini tyres https://ausmini.com/forums/viewtopic.php?f=2&t=94649 |
Author: | Ozrider [ Sat Jan 14, 2017 9:58 pm ] |
Post subject: | Standard 850 mini tyres |
Hi All What size tyres and wheels can I fit to the car to get it through a RWC and still make it a look ok?? Once it's got a RWC and it's club plated I can look at other options. |
Author: | timmy201 [ Sun Jan 15, 2017 5:49 am ] |
Post subject: | Re: Standard 850 mini tyres |
If you're using the standard 850 wheels the normal tyre option is the Falken SN807 - 145/80R10. Depending on the shop you go to you might need inner tubes. E.g. http://minisport.com.au/10-mini-falken-tyrea-145x80xr10 Might be worth checking if you can put mag wheels on for RWC or if you need standard, save buying twice. |
Author: | Ozrider [ Sun Jan 15, 2017 7:09 am ] |
timmy201 wrote: If you're using the standard 850 wheels the normal tyre option is the Falken SN807 - 145/80R10. Depending on the shop you go to you might need inner tubes. E.g. http://minisport.com.au/10-mini-falken-tyrea-145x80xr10 Might be worth checking if you can put mag wheels on for RWC or if you need standard, save buying twice. Thanks, will a wider tyre rub on the body or swingarm with a standard setup or will they need spacers / flares? |
Author: | timmy201 [ Sun Jan 15, 2017 7:24 am ] |
The 145 tyre is the only one that works with the stock 3.5" wide steel wheels. You can easily fit 5" wide alloys and 165 tyres on a stock 850, mine has 10x5 Contessa wheels with 165 Yokohama A008 tyres and no rubbing anywhere. No flares or spacers ![]() |
Author: | Ozrider [ Sun Jan 15, 2017 7:32 am ] |
timmy201 wrote: The 145 tyre is the only one that works with the stock 3.5" wide steel wheels. You can easily fit 5" wide alloys and 165 tyres on a stock 850, mine has 10x5 Contessa wheels with 165 Yokohama A008 tyres and no rubbing anywhere. No flares or spacers ![]() Perfect, just what I was after, thanks. P.S. Car looks awesome |
