What should i be paying / selling for? https://ausmini.com/forums/viewtopic.php?f=2&t=94634 |
Author: | Asiemek [ Fri Jan 13, 2017 12:02 pm ] |
Post subject: | What should i be paying / selling for? |
hi all, looking at selling 1100S block no caps, surface rust, looks like its been bored out (unknown amount) also, what should I be looking at paying for a Mk1 S crank (if anyone has one)? |
Author: | TK [ Fri Jan 13, 2017 12:50 pm ] |
Post subject: | Re: What should i be paying / selling for? |
your block, $100? to buy an uncracked Cooper S crank 800 to 1000 if standard to 010. |
Author: | drmini in aust [ Fri Jan 13, 2017 1:32 pm ] |
I agree with TK. Block would be worth much more with original caps. Like $350+. Buying new steel caps and line boring it will cost a heap of money. |
Author: | gtogreen1969 [ Fri Jan 13, 2017 3:29 pm ] |
Watch what this block goes for. http://www.ebay.com.au/itm/Morris-Coope ... SwjDZYdzls Can't see any caps with it. |
Author: | timmy201 [ Fri Jan 13, 2017 3:35 pm ] |
gtogreen1969 wrote: Watch what this block goes for. http://www.ebay.com.au/itm/Morris-Coope ... SwjDZYdzls Can't see any caps with it. The numbers on that looks like the same guy who stamped mine, it's an 1100S Auto block. |
Author: | gtogreen1969 [ Fri Jan 13, 2017 3:43 pm ] |
timmy201 wrote: gtogreen1969 wrote: Watch what this block goes for. http://www.ebay.com.au/itm/Morris-Coope ... SwjDZYdzls Can't see any caps with it. The numbers on that looks like the same guy who stamped mine, it's an 1100S Auto block. Haven't seen that format before. 12H169 / H695. |
Author: | timmy201 [ Fri Jan 13, 2017 3:47 pm ] |
gtogreen1969 wrote: timmy201 wrote: gtogreen1969 wrote: Watch what this block goes for. http://www.ebay.com.au/itm/Morris-Coope ... SwjDZYdzls Can't see any caps with it. The numbers on that looks like the same guy who stamped mine, it's an 1100S Auto block. Haven't seen that format before. 12H169 / H695. The three numbers on the end are the serial number. From way back: Morris 1100 wrote: drmini in aust wrote: Q for Morris 1100- Maaaate, I have a block here from an 1100S auto, it's 12H169/H321 Any idea what vintage? ![]() Jan 69 to May 69. Probably closer to Jan than May. They only built the Morris 1100S automatic for five months and about 700 cars. The early cars had a fully imported powerplant with the 12H169/H and the later ones had the Australian produced one with the 12YA/A/H prefix. |
Author: | gtogreen1969 [ Fri Jan 13, 2017 3:52 pm ] |
I forgot about the early Auto Blocks. Mine was a later 12YEAH. No mention of it being an auto block in the add. |
Author: | TheMiniMan [ Sat Jan 14, 2017 9:01 am ] |
usually nothing wrong with auto blocks really very little fatigue with these, old ladys driving to church on sunday etc ![]() all that`s required to change to manual is--> an oil pump adaptor plate (which we have hundred of in stock) fit said plate, drill oil gallery right through to meet said oil pump adaptor plate remove oil-pressure reliefe valve "Seat" , fill both "through-holes" & re-fit & drill dip-stick hole also remove all the excess studs from base flange it`s now a manual block ![]() easy-peasy normally these 1300 auto blocks are either std or 020 bore so excellent for reco Matt 0407 135 656 |
Author: | drmini in aust [ Sat Jan 14, 2017 12:19 pm ] |
What Matt said ^^ I also found it needed a gasket between the oil pump spacer and the block. |
