https://ausmini.com/forums/
Rad Top Hose Size
https://ausmini.com/forums/viewtopic.php?f=2&t=94625
Author:  MiniBob [ Wed Jan 11, 2017 9:28 pm ]
Post subject:  Rad Top Hose Size
So the rad has a 25mm spout and the 'stat is the same size.
The only size hose that is the correct shape is 28mm ID.
Is there a source for either silicon or rubber hose that would fill the gap?
So needs to be 25mm ID / 28 mm OD and about 1.5mm wall thickness.
I could then fit the top hose over it.
I have searched muchly with no luck.
Author:  Phil 850 [ Thu Jan 12, 2017 7:27 pm ]
Post subject:  Re: Rad Top Hose Size
So why won't a standard radiator top hose fit like this
http://minikingdomonline.com.au/product ... ose-top-4/
Author:  MiniBob [ Thu Jan 12, 2017 7:52 pm ]
Thanks for the pic mate. Hard to be certain but it looks too flat.
Because of my set up there is a step of about 20mm between the MPi stat housing and the rad tube.
Author:  Matt I [ Fri Jan 13, 2017 12:17 am ]
http://minispares.com/product/Classic/Cooling_heating/GRH1212.aspx
This hose looks to be offset to work with the sandwich plate.
Author:  MiniBob [ Fri Jan 13, 2017 7:35 pm ]
That looks the go! Thanks Matt I. Will get one ordered
