Gearbox Casing Swaparoozy? https://ausmini.com/forums/viewtopic.php?f=2&t=94593 |
Author: | haze blue 850 [ Sat Jan 07, 2017 7:13 pm ] |
Post subject: | Gearbox Casing Swaparoozy? |
Greetings Mini Experts. Have a noisy 22G1128 (4 sync) in my wife's car. Remote shift. Also have a perfect 22G1832 (4 sync) but Rod shift. Can I simply swap the insides, to keep a Remote shift. Are the casings (other than diff / shifter types) the same? Alex. |
Author: | drmini in aust [ Sat Jan 07, 2017 8:34 pm ] |
Post subject: | Re: Gearbox Casing Swaparoozy? |
All gears and shafts are same early rodchange to 4 synchro remote, except reverse gear. So you can put the rodchange gear train in, but use the remote box reverse gear. Edit reverse gear difference is the selector fork groove position. |
Author: | haze blue 850 [ Sat Jan 07, 2017 9:09 pm ] |
Thanks Doc. Will give it a go! Cheers Alex. |
