12V charger Socket fitting with dynamo https://ausmini.com/forums/viewtopic.php?f=2&t=94532 |
Author: | peterb [ Sun Jan 01, 2017 7:50 am ] |
Post subject: | Re: 12V charger Socket fitting with dynamo |
Shouldn't be a problem with it, most modern units can handle fluctuations and I doubt the system will ever put out too much power. Have you concidered changing it to negative earth, no parts or modifications involved and you can swap it back at any time. |
Author: | niffty64 [ Sun Jan 01, 2017 8:19 am ] |
peterb wrote: Shouldn't be a problem with it, most modern units can handle fluctuations and I doubt the system will ever put out too much power. Have you concidered changing it to negative earth, no parts or modifications involved and you can swap it back at any time. thanks peter. i think i would only consider changing over if i was to fit a alternator. I would like to leave the generator just to keep it original. i don't intend on adding any other electrical items such as radio or heater so it shouldnt be a problem |
Author: | DavidE [ Sun Jan 01, 2017 8:44 am ] |
niffty64 wrote: peterb wrote: Shouldn't be a problem with it, most modern units can handle fluctuations and I doubt the system will ever put out too much power. Have you concidered changing it to negative earth, no parts or modifications involved and you can swap it back at any time. thanks peter. i think i would only consider changing over if i was to fit a alternator. I would like to leave the generator just to keep it original. i don't intend on adding any other electrical items such as radio or heater so it shouldnt be a problem My Deluxe is running a generator and has been converted to Negative earth. You don't need to replace the generator with an alternator. |
Author: | niffty64 [ Sun Jan 01, 2017 9:03 am ] |
DavidE wrote: niffty64 wrote: peterb wrote: Shouldn't be a problem with it, most modern units can handle fluctuations and I doubt the system will ever put out too much power. Have you concidered changing it to negative earth, no parts or modifications involved and you can swap it back at any time. thanks peter. i think i would only consider changing over if i was to fit a alternator. I would like to leave the generator just to keep it original. i don't intend on adding any other electrical items such as radio or heater so it shouldnt be a problem My Deluxe is running a generator and has been converted to Negative earth. You don't need to replace the generator with an alternator. The positive earth isn't the issue. what i was concerned about was the fluctuating voltage.and where the best place to wire into the circuit. ![]() |
Author: | peterb [ Sun Jan 01, 2017 9:52 am ] |
main lead from battery, maybe through switch/fuse. |
Author: | AJ [ Sun Jan 01, 2017 12:02 pm ] |
Connect black wire (-ve) to fuse (21) same side as the green wires connect to .This fuse is switched by the ignition switch . Connect red wire (+ve) to earth ![]() Edit : Most electronic equipment these days have internal voltage stabiliser circuit and polarity protection |
Author: | niffty64 [ Sun Jan 01, 2017 1:14 pm ] |
AJ wrote: Connect black wire (-ve) to fuse (21) same side as the green wires connect to .This fuse is switched by the ignition switch . Connect red wire (+ve) to earth ![]() Edit : Most electronic equipment these days have internal voltage stabiliser circuit and polarity protection thanks AJ exactly what i needed ![]() |
Author: | Phil 850 [ Sun Jan 01, 2017 8:48 pm ] |
AJ wrote: Connect black wire (-ve) to fuse (21) same side as the green wires connect to .This fuse is switched by the ignition switch . Connect red wire (+ve) to earth ![]() Edit : Most electronic equipment these days have internal voltage stabiliser circuit and polarity protection We fitted a 12V socket fitted to my daughters 850 with positive earth. I wrongly assumed the the Garmin GPS would have polarity protection, it didn't ![]() If yours is a 2 wire socket, connect it around the correct way, just to be sure ![]() |
Author: | Bubbacluby [ Mon Jan 02, 2017 4:36 pm ] |
I am running a generator on my moke and have a cigarette lighter connected up. I run my GPS, charge phones etc without issue. It has been changed to negative earth though. Don't think it would work and it would cause problems if still positive earth. Sent from my SM-G935F using Tapatalk |
Author: | niffty64 [ Mon Jan 02, 2017 7:08 pm ] |
Bubbacluby wrote: I am running a generator on my moke and have a cigarette lighter connected up. I run my GPS, charge phones etc without issue. It has been changed to negative earth though. Don't think it would work and it would cause problems if still positive earth. Sent from my SM-G935F using Tapatalk when i purchased the cigarette lighter socket i chose one with a plastic body so the body wasn't earth and just wire it so the red wire was earth job done. |
