It is currently Sun Jul 20, 2025 10:22 am
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri May 12, 2017 11:22 pm
Are the demister vent tubes to suit a Mk2 Cooper S plastic heater available as a reproduction anywhere? If so how exact are they to the original?
Or if not available would anybody know where to source some good second hand ones from or are they rare as hens teeth... :(
Mark
PostPosted: Sun May 14, 2017 1:02 pm
http://oz.minisport.com/czh1753-heater- ... -1992.html
I'm in need of the same on mine, this was the only local pipe I had seen.
1968 Morris Mini Traveller - Woody (under restoration)
PostPosted: Sun May 14, 2017 1:08 pm
Raz wrote:
http://oz.minisport.com/czh1753-heater-ducting-pipe-to-screen-22-5-x-1-25-1967-1992.html
Thanks Raz!
Not sure how close to the originals they are but il get in contact with them to see.
Thanks again mate! :D
PostPosted: Sun May 14, 2017 1:46 pm
I may have some in a box somewhere in the shed. I saw 3 of them a few years ago. Are they a convoluted plastic about 40mm diameter?
PostPosted: Sun May 14, 2017 2:36 pm
MKO has genuine Rover versions.
http://minikingdomonline.com.au/product ... over-part/
PostPosted: Sun May 14, 2017 3:03 pm
I believe the original mk1 are fibre/foil and mk2 onwards was plastic, not sure but assume the rover fit just the same.
PostPosted: Sun May 14, 2017 6:14 pm
Strange how the mk2 got plastic and the clubman GT went back to the cardboard and aluminium tubing.
Mk2 2 is very similar to household vacuume pipe isn't it?
Sent from my SM-G935F using Tapatalk
PostPosted: Sun May 14, 2017 7:20 pm
not on my 7/70 car... I'm 99.99% sure mine is original and it's paper/foil
PostPosted: Sun May 14, 2017 7:26 pm
Yes, black paper and inner foil on my Sept 70 MK II.
PostPosted: Sun May 14, 2017 7:59 pm
Ok. Makes sense now. Thanks.
Now to find kopex in the correct diameter.
The tubing is still available if you search hard enough.
PostPosted: Sun May 14, 2017 8:03 pm
Thanks guys for your knowledgeable input. Really appreciated!
The year of my MK2 is the same as Simons- 7/70 so it would appear to be the black paper/inner foil type?
Thanks Brad, if you have this type or anyone, id be interested in them if there in good nick but hearing there construction it may be hard to find an intact good set?
Bubbacluby- Is Kopex the brand name or product name of this black paper/inner foil type tubing?
PostPosted: Sun May 14, 2017 11:24 pm
Here are a few photos of the ones i have. They must be later leyland ones. I have never really taken any notice of the ducting before. Out of sight out of mind. ImageImage
PostPosted: Mon May 15, 2017 4:37 pm
sounds like early Porsches use the same stuff... http://www.early911sregistry.org/forums ... php?111174
PostPosted: Mon May 15, 2017 4:39 pm
wooo.... looks a lot like this: https://www.aasesales.com/products/g2e-s54-8i-103189
$10 a piece would be worth having a look - though 55mm might be too big, need to measure
PostPosted: Mon May 15, 2017 4:51 pm
hahaha!!
"aluminiumflexibledutcing.com"
http://www.aluminumflexibleducting.com/ ... -hose.html
Users browsing this forum: Scoop and 86 guests
