https://ausmini.com/forums/
Indicators + unconnected wire
https://ausmini.com/forums/viewtopic.php?f=2&t=94510
Author:  Hobson [ Wed Dec 28, 2016 9:57 pm ]
Post subject:  Indicators + unconnected wire
Now drove home tonight, realized I did not have a rear left hand flasher, no light either, but solid amber to the front. I would be guessing there isn't enough load without the rear globe to get the front to flash, should not be the flasher unit as the right hand works fine. Thoughts?
I also noticed a black/white or a white/black wire loose, with a bullet connector around the same location as the connection to the indicator stalk. I had a quick look and didn't notice a corresponding wire, will go have a better look tomorrow. I also had a look at some wiring diagrams and the only bw or wb wire was coil related. (all for a oct 78 Leyland mini S)
Author:  Stev0 [ Thu Dec 29, 2016 5:41 am ]
Post subject:  Re: Indicators + unconnected wire
I can only say that if a globe is gone the flasher usually flashes quickly. Check the globe then the wiring.. Can you see where the wire goes to?
Author:  Hobson [ Thu Dec 29, 2016 2:00 pm ]
In terms of the indicator it was the globe, the man at bursons was confused about that fact that it had twin "nodes" on the bottom, hey it works so I said match it and he did.
The wire appears to go to the coil and I am guessing it is a feed to the Coil for a tac, Handy for when I actually put that in.
Author:  Hobson [ Tue Jan 17, 2017 10:55 am ]
Would anyone with a '78 LS or similar with a factory tac. be able to check if they have a white wire with black trace going to their coil please?
Author:  simon k [ Tue Jan 17, 2017 4:26 pm ]
far out... just pathetic that he doesn't know what a twin filament globe is...
