Cooper S Engine Removal https://ausmini.com/forums/viewtopic.php?f=2&t=94485 |
Author: | GundyGuy [ Mon Dec 26, 2016 6:03 pm ] |
Post subject: | Cooper S Engine Removal |
Well today was the day Take the engine out to freshen it up The issues i found were 1- the Hardy Spicer uni's wont slide back far enough to release from the diff flanges due to the bolt length 2- where the remote gear shift bolts too is rather long and required a reasonable tilt of the engine to get the lot out Other than that is was just a lot of small fiddly stuff and the brake booster in the way **With problem 1 it is best to remove the bolts before fitting the engine back in so the uni's can be re-fitted easier |
Author: | Mick [ Mon Dec 26, 2016 6:13 pm ] |
Post subject: | Re: Cooper S Engine Removal |
I simply undo the top ball joints on the hubs and rock them out a little. That allows enough spline to slide the unis over the bolts. |
Author: | 1071 S [ Mon Dec 26, 2016 6:27 pm ] |
I must have the wrong end of the stick.... The HS uni flange unbolts from the diff output flange and the diff just slides straight apart???? Splines don't come into it.... And yes, the engine needs to be tilted right back. Lifting lugs fitted into the spark plug holes provide the perfect angle... It is annoying that the distance between the subframe and top front cross member is EXACTLY the same as the distance from the top back of the remote mount to the bottom corner of the gearbox. Would it really hurt to give us a spare 3 or 4 mm.... ![]() Cheers, Ian |
Author: | drmini in aust [ Tue Dec 27, 2016 6:43 am ] |
I find you need to remove all 8 nyloc nuts, lift engine slightly then slide motor to one side. The other side uni flange will then clear the studs. Some folks I know punch the studs/bolts out for quicker assembly. |
