Outer Door Handles https://ausmini.com/forums/viewtopic.php?f=2&t=94446 |
Author: | GundyGuy [ Sun Dec 18, 2016 4:53 pm ] |
Post subject: | Outer Door Handles |
Well spent most of Sat removing the door lock and outer door handle assembly to fit new ones to the passenger side I bought a new door lock and fitted that latch and lock assembly for an Aussie mini, made new rivets and re-assembled it The biggest problem was the dodgy spiral spring that wouldn't fit over the square shaft of the new handle So after remaking the square centre of the spring i was getting close to finishing it Lucky i had a magnetic pick up tool for retrieving the dropped screws etc NOW the question is Is it normal for the outer door handle mount to distort the door skin a little when fitting it Or is there a secret trick to prevent this I was thinking the new rubber was a bit thick After what i did i feel it would be better to remove the whole door and work on it on its side |
Author: | GundyGuy [ Tue Dec 20, 2016 1:55 pm ] |
Post subject: | Re: Outer Door Handles |
Anyone had this problem Sent from my HTC_PN071 using Tapatalk |
Author: | Minicooper4me [ Tue Dec 20, 2016 6:22 pm ] |
Done mine recently Gundy. Doors were already on, a ning nong of a job but I didn't seem to have too much trouble. Only swore about 50 times so that't pretty normal. |
Author: | GundyGuy [ Wed Dec 21, 2016 5:21 am ] |
Did you notice if the door handle surround had distorted the door skin at all |
Author: | Minicooper4me [ Wed Dec 21, 2016 8:15 am ] |
No distortion. |
Author: | GundyGuy [ Wed Dec 21, 2016 9:52 am ] |
I wonder what's going on with mine Sent from my HTC_PN071 using Tapatalk |
Author: | clovus [ Sat Dec 24, 2016 6:49 pm ] |
Never had a problem with mine. Is there a right and left side door handle? That might explain it? |
