It is currently Thu Jul 24, 2025 8:23 am
 Post subject: Outer Door Handles
PostPosted: Sun Dec 18, 2016 4:53 pm
Well spent most of Sat removing the door lock and outer door handle assembly to fit new ones to the passenger side
I bought a new door lock and fitted that latch and lock assembly for an Aussie mini, made new rivets and re-assembled it
The biggest problem was the dodgy spiral spring that wouldn't fit over the square shaft of the new handle
So after remaking the square centre of the spring i was getting close to finishing it
Lucky i had a magnetic pick up tool for retrieving the dropped screws etc
NOW the question is
Is it normal for the outer door handle mount to distort the door skin a little when fitting it
Or is there a secret trick to prevent this
I was thinking the new rubber was a bit thick
After what i did i feel it would be better to remove the whole door and work on it on its side
1970 MK2 Cooper S
 Post subject: Re: Outer Door Handles
PostPosted: Tue Dec 20, 2016 1:55 pm
Anyone had this problem
Sent from my HTC_PN071 using Tapatalk
1970 MK2 Cooper S
PostPosted: Tue Dec 20, 2016 6:22 pm
Done mine recently Gundy. Doors were already on, a ning nong of a job but I didn't seem to have too much trouble. Only swore about 50 times so that't pretty normal.
PostPosted: Wed Dec 21, 2016 5:21 am
Did you notice if the door handle surround had distorted the door skin at all
1970 MK2 Cooper S
PostPosted: Wed Dec 21, 2016 8:15 am
No distortion.
PostPosted: Wed Dec 21, 2016 9:52 am
I wonder what's going on with mine
1970 MK2 Cooper S
PostPosted: Sat Dec 24, 2016 6:49 pm
Never had a problem with mine. Is there a right and left side door handle? That might explain it?
