Med roller tip rockers https://ausmini.com/forums/viewtopic.php?f=2&t=94426 |
Author: | GundyGuy [ Fri Dec 16, 2016 10:31 am ] |
Post subject: | Med roller tip rockers |
Has anyone fitted these rockers and found the spacers to have a fair amount of side clearance. MED said that this isn't a problem after I enquired about a shim kit to remove this excess side play |
Author: | drmini in aust [ Fri Dec 16, 2016 12:15 pm ] |
Post subject: | Re: Med roller tip rockers |
Depends how much... I would sooner have some side play than have them tight. I fitted a set of Minisport UK ones a while back for someone and had to machine 2 of the 3 spacers shorter to stop them jamming. |
Author: | GundyGuy [ Fri Dec 16, 2016 4:37 pm ] |
I am talking like maybe 0.025" sideplay |
Author: | drmini in aust [ Fri Dec 16, 2016 4:47 pm ] |
A shim would be good but shaft in these is 17.0mm. an odd size. |
Author: | GundyGuy [ Sun Dec 18, 2016 6:17 am ] |
I might just turn up some new spacers to fix it |
Author: | 68Rusty [ Sun Dec 18, 2016 8:26 am ] |
drmini in aust wrote: Depends how much... I would sooner have some side play than have them tight. I fitted a set of Minisport UK ones a while back for someone and had to machine 2 of the 3 spacers shorter to stop them jamming. I had to mix and match the mini sport spacers to even out the tolerance between rockers. I think 1 or two of the spacers were a little longer than the others. Sent from my iPhone using Tapatalk |
Author: | GundyGuy [ Wed Dec 21, 2016 9:55 am ] |
Machined up some new spacers 0.030-0.035 wider Sent from my HTC_PN071 using Tapatalk |
