It is currently Thu Jul 24, 2025 8:20 am
 Post subject: Med roller tip rockers
PostPosted: Fri Dec 16, 2016 10:31 am
Has anyone fitted these rockers and found the spacers to have a fair amount of side clearance. MED said that this isn't a problem after I enquired about a shim kit to remove this excess side play
1970 MK2 Cooper S
PostPosted: Fri Dec 16, 2016 12:15 pm
Depends how much...
I would sooner have some side play than have them tight. I fitted a set of Minisport UK ones a while back for someone and had to machine
2 of the 3 spacers shorter to stop them jamming.
PostPosted: Fri Dec 16, 2016 4:37 pm
I am talking like maybe 0.025" sideplay
1970 MK2 Cooper S
PostPosted: Fri Dec 16, 2016 4:47 pm
A shim would be good but shaft in these is 17.0mm. an odd size.
PostPosted: Sun Dec 18, 2016 6:17 am
I might just turn up some new spacers to fix it
1970 MK2 Cooper S
PostPosted: Sun Dec 18, 2016 8:26 am
Depends how much...
I had to mix and match the mini sport spacers to even out the tolerance between rockers. I think 1 or two of the spacers were a little longer than the others.
Mini's I grew up with
Slot car couch
PostPosted: Wed Dec 21, 2016 9:55 am
Machined up some new spacers 0.030-0.035 wider
Sent from my HTC_PN071 using Tapatalk
1970 MK2 Cooper S
