It is currently Sat Jul 26, 2025 9:49 pm
 Post subject: Cv Joints
PostPosted: Fri Dec 16, 2016 12:50 pm
Just bought and fitted new disc brake (outer) CV joints to my Clubman. These now have a thick outer washer under the nut. Any thoughts on this.
 Post subject: Re: Cv Joints
PostPosted: Fri Dec 16, 2016 1:26 pm
as long as the washer is only pressing on the tapered washer thing that goes into the drive flange it's OK. If the washer is pressing on the drive flange then the tapered washer isn't doing it's job and it'll be bad news
PostPosted: Fri Dec 16, 2016 4:12 pm
I think in the kit, the instructions (yes, I actually read them once :)) says that the big washer is there for torquing purposes only.
It's gotta be then removed for final fitment and fitting the split pin.
PostPosted: Fri Dec 16, 2016 7:38 pm
Stuwey, Mine didn't have any instructions, but I thought your instructions would be the way to go.
PostPosted: Fri Dec 16, 2016 8:15 pm
MinisPlus
On a Disc type C.V. the thick flat washer is not used. I don't know why it's even included but you don't use it.
Count it as a handy free thick washer for somthing useful in the future or just throw it out abd fit up the joint as per the original design.
-Ben.
How can it be rusty when it's covered in so much oil?
